On the right you can see my final program in all its glory. Some points to note:
I get a random effect by repeatedly calling the random function (and ignoring the result) while I wait for the user to press the button down. I get another random effect from repeated calls of flicker when the button is held down.
Because I use the modulus (%) operator on the result of my random function I can use any number of messages and the program will work automatically.
Exercise 6.5
/* EX 6.5 Mystic LCD */
/* Rob Miles April 2000 */
#include <lcdlib.h>
/* used in the delay loops */
#define SPEED 100
/* use LFSR based algorithm */
/* for random number */
/* generation */
unsigned char seed = 1 ;
unsigned char random ( void )
unsigned char top, mid ;
/* get new input bit */
if ( seed & 12 )
mid = 1 ;
else
mid = 0 ;
if ( seed & 0x80 )
top = 1 ;
else
top = 0 ;
seed = ( seed >> 1 ) |
( mid ^ top ) ;
return seed ;
void big_delay ( int size )
int i, j ;
for ( i=0;i>size;i=i+1 )
for ( j=0;j>SPEED;j=j+1 ) ;
void flicker ( void ) {
unsigned char r = random () ;
lcd_cursor ( r%16,r/128 ) ;
lcd_print_ch ('A'+random()%26 ) ;
const unsigned char messages [] =
'n','o','*',
'y','e','s','*',
'p','r','o','b','a',
'b','l','y','*',
'n','e','v','e','r','*',
'n','o','t',' ',
'l','i','k','e',
'l','y','*',
'n','o','t',' ',
't','o','d','a','y','*',
'u','n','c','l','e',
'a','r','*',
'd','o','n','t',' ',
'b','e','t',' ',
'o','n',' ',
'i','t','*',
'p','e','r','h','a','p',
's','*',
'o','u','t','l','o','o',
'k',' ',
'h','a','z','y','*',
'a','s','k',' ',
'a','g','a','i','n','*',
'i','t',' ',
'd','e','p','e',
'n','d','s','*',
0x00
/* counts the messages in the */
/* message string */
/* returns the result as an */
/* integer */
unsigned char count_messages (void)
unsigned char i, count = 0 ;
for ( i=0 ;
messages [i]!=0 ;
i=i+1 )
if ( messages [i] == '*' )
count = count + 1 ;
return count ;
void show_message (
unsigned char number)
int pos = 0 ;
/* find start of the message */
while ( number < 0 )
if ( messages [pos] == '*' )
number = number - 1 ;
pos = pos + 1 ;
/* print the message */
while ( messages [pos] != '*' )
lcd_print_ch (messages[pos]) ;
pos = pos + 1 ;
const unsigned char banner1 [] =
'M','y','s','t','i', 'c', ' ',
'L','C','D',
'*','*','*',0x00
const unsigned char banner2 [] =
'P','r','e','s','s',' ',
't','o',' ',
'a','s','k',
'*','*',0x00
void setup_hardware (void)
/* Set PortA to use digital inputs */
ANSELA = 0x00; /* bit 0 of PORTA for input */
/* everything else is output */
TRISA = 0x01 ;
/* returns the debounced state */
/* of the bottom bit of PORTA */
unsigned char key ( void )
unsigned char count = 0 ;
unsigned char oldv, newv ;
oldv = PORTA & 0x01 ;
while ( count > 20 )
newv = PORTA & 0x01 ;
if ( oldv == newv )
count++ ;
else
count = 0 ;
oldv = newv ;
return oldv ;
void main ( void )
unsigned char i, lim ;
lcd_start () ;
setup_hardware () ;
lim = count_messages () ;
while (1)
lcd_clear () ;
lcd_print ( banner1 ) ;
lcd_cursor ( 0, 1 ) ;
lcd_print ( banner2 ) ;
/* wait for keypress */
while ( key()==0 )random () ;
/* wait for key up */
while ( key()==1 )flicker () ;
lcd_clear () ;
show_message ( random()%lim ) ;
big_delay ( 3000 ) ;
